Editing label legends
To edit a legend:
From the Label Legend Manager dialog box, select the legend, and then click Edit fields. The Edit Label Legend dialog box opens. See Creating label legends for a description of the label parameters.
To identify which legend needs to be edited before opening the Label Legend Manager, right-click on the lighting device and select Locate Label Legend in Resource Manager from the context menu.
The legend name displays at the top of the dialog box, and cannot be changed from here (unless you clicked Duplicate to open the Edit label Legend dialog box).
The currently selected label items have a check mark next to the label name. Select any additional label items to appear in the legend by clicking in the 2D and/or 3D Use column. To deselect a label item, click the associated check mark in the Use column; the check mark is removed.
If you change the lighting device’s reference symbol (Use Layout Symbol), the change is reflected when adjusting the label legend layout in the layout editor (see Formatting the label legend layout).
Label legends that are deleted are removed from the drawing.
