Swapping lighting devices
Command |
Path |
Swap Lighting Devices |
Context menu |
Two lighting devices can swap their geometric position and certain data. All accessories move with their associated device.
Most of the device data moves automatically with the lighting device to its new location. Exceptions are the Unit Number and Position values, which never move with the device. You have the option to move the Circuit Name, Circuit Number, Dimmer, and Universe/Address values or keep the devices' original data.
To swap two lighting devices:
Select the devices; nothing else can be selected.
Select the command; the Swap Lighting Devices dialog box opens.
Pressing the Shift key while selecting the command either suppresses or displays the dialog box, depending on the option selected for Shift+click behavior the last time you used the dialog box.
Set the desired options.
Parameter |
Description |
Move data from the following fields |
Select which data to move with the lighting device to its new location. Selecting a field means the lighting device keeps its original data. Deselecting a field means the lighting device uses the data from the swapped device. Except for Unit Number and Position, all other fields that are not listed in the dialog box automatically move with the lighting device to its new location. |
Shift+click |
Select what happens when you press the Shift key when selecting the Swap Lighting Devices command. Move data immediately using previous settings: Swaps the lighting devices without showing the dialog box, using the most recent settings. Display this dialog box: Opens the Swap Lighting Devices dialog box so you can adjust the settings before swapping the lighting devices. |
