Managing accessories
There are several ways to manage accessories, depending on their position and the number of lighting devices you are working with. The following table lists different methods for inserting, editing, and deleting accessories—on one lighting device or many devices at once.
Action
Method
Description
Inserting accessories
Insert an accessory in the default position on one or more lighting devices
Lighting Accessory tool in the drawing area
Lighting Accessory tool in accessory edit mode
Inserting accessories in the default position
Insert an accessory in a custom position on one or more lighting devices
Inserting accessories in a custom position
Changing the accessory data
Edit the device parameters of one or more accessories
Edit Accessory parameter on the Object Info palette of the associated lighting device
Accessory Object Info palette
Lighting device properties
Adjusting accessories
Adjusting the accessory location and rotation
Edit the 2D location of an accessory on one or more lighting devices
X/Y Offset (2D View) parameters on the accessory Object Info palette
Click-drag operation
Edit the angle of plan rotation for an accessory on one or more lighting devices
Plan Rotation parameter on the accessory Object Info palette
Edit the 3D location of an accessory on one or more lighting devices
X/Y/Z parameters on the accessory Object Info palette
Edit the 3D orientation of an accessory on one or more lighting devices
X/Y/Z Rotation parameters on the accessory Object Info palette
Remove accessories
Delete an accessory from a single lighting device
Delete key in accessory edit mode, when editing a single selected lighting device
Removing a single accessory
Delete the same accessory from a selection of lighting devices
Delete key in accessory edit mode, when editing multiple selected lighting devices
Delete all accessories from one or more lighting devices
Removing all accessories
Concept: Lighting accessories
Inserting and removing accessories in the drawing area
Accessory edit mode
Inserting accessories in accessory edit mode
