ArchitectCreating a circuit
Tool
Tool set
Circuiting
MEP
To create a circuit:
Click the tool.
Click the first item to be circuited.
If you select a custom symbol without a Circuiting record attached, the tool attaches the record to the current symbol, as well as to all subsequent symbols in the circuit. In this case, specify whether an electrical or communication circuit is being created.
When creating a circuit, do not include the panel symbol.
Based on the item’s record, the tool determines whether this is an electrical or communication device. The Circuiting Tool dialog box opens.
Parameter
Description
Circuit Information
Enter the circuit information (used on the panel schedule)
Panel
Select the associated panel
Circuit #
Enter the circuit number
Trip
Enter the trip rating
Wire Size
Enter the size of the wire
Conduit Size
Enter the conduit size
V.A./Watts
Enter the total V.A./Watts rating
Remarks
Enter remarks for the circuit
Check Voltage and Phase of Circuit Items
Verifies that the voltage and phase of circuited items is correct
Draw circuiting lines
Draws connecting circuiting lines
Overwrite existing object data
Applies the current object information to all objects in the circuit
Object Data
Enter parameters for the object being circuited
Phase/Pole
Enter the number of phases/poles
Voltage
Enter the voltage
V.A./Watts
Enter the V.A./Watts for this object
Remarks
Enter remarks for the object
Enter the desired information for the circuit and the objects in the circuit.
The information is transferred to the object’s record.
Continue clicking on the items to be circuited in the order the circuit loop should be drawn.
To complete the circuit, click in an empty area of the drawing. Confirm that you wish to place the Home Run marker.
The Circuiting tool generates a Home Run marker and phases are denoted as specified.
