Design SuiteConverting notes from previous versions
Command
Path
Convert Old Notes to New
Text
Databases created in previous versions of the Notes Manager are automatically converted to the current version when they are selected by clicking Choose to select a database.
Databases and notes created in Vectorworks versions prior to version 11 can be converted for use in the current version. Callouts created in those versions are automatically converted to the current format. They can be used as ordinary callouts, keynotes, or database callouts. Other notes objects, such as Text Notes, Keynotes, and General Notes created by previous Notes Manager versions, as well as Vectorworks text objects, must be converted. Vectorworks text objects are converted to general notes.
To convert old objects to the current format:
Select the command. The Convert Old Notes to New dialog box opens. Select the type of old notes to convert.
Parameter
Description
All updatable objects
Converts any note-related items in the drawing
All selected objects
Converts any note-related items in the current selection
Just the following objects
Select the type of objects to be converted (Text Notes, Keynotes, General Notes from version 8.52 to 10, and text objects)
Layers/Classes
Specifies the layers and classes to be searched for objects to convert
The Conversion Results dialog box displays a summary of the objects converted.
Notes management with databases
Concept: Notes management
