Moving objects in 3D space
| Command | Path | Shortcut |
| Move 3D | Modify > Move | Ctrl+Alt+M (Windows) Cmd+Option+M (Mac) |
To move an object in 3D space by command:
Select the object to move.
Select the command.
The Move 3D Selection dialog box opens.
| Parameter | Description |
| Layer Plane | Select the X, Y, Z (layer plane) coordinate system |
| X, Y, Z Offset | For layer plane coordinates, specify the distance to move the object |
| Working Plane | Select the X’, Y’, Z’ (working plane) coordinate system |
| X’, Y’, Z’ Offset | For working plane coordinates, specify the distance to move the object |
The object is moved in 3D space according to the criteria specified.
