Joining objects
The Join commands can be used to join two single lines, two double lines, or two walls together. Joined lines intersect but remain as individual objects.
Object
Command
Specifications
Individual Lines
Join
Join (No Trim)
An individual line can be joined to another individual line
Double Lines
Join
Join and Fillet
Double lines can be joined to another set of double lines or to a wall. Double lines drawn with the Create Polygons option (set in Double Line preferences) cannot be joined. Only the line elements of double lines drawn with the Create Lines and Polygons option can be joined.
Walls
Join
Join (No Trim)
A wall can be joined to another wall or to double lines created with the Create Lines option (set in Double Line preferences). Walls will join to the line elements of double lines drawn with the Create Lines and Polygons option.
Join
Command
Path
Shortcut
Join
Modify > Join
Ctrl+J (Windows)
Cmd+J (Mac)
To join walls, single lines, or double lines:
Select the two non-parallel walls, lines, or double lines to join.
Select the command.
The selected walls/lines are joined together with any excess trimmed away.
Join and fillet
Command
Path
Shortcut
Join and Fillet
Modify > Join
Ctrl+J (Windows)
Cmd+J (Mac)
To join and fillet double lines:
Select the two sets of non-parallel double lines to join.
Select the command.
If a fillet measurement has already been specified for this drawing, the two double lines are connected and filleted using the default value.
If a fillet measurement has not yet been specified for this drawing, the Fillet Settings dialog box opens.
Enter the desired fillet radius.
The Fillet Settings dialog box is accessible from various locations in the Vectorworks program, whenever a fillet radius value can be set. A change to the radius value in one location changes the default setting in all locations.
Join (no trim)
Command
Path
Shortcut
Join (no trim)
Modify > Join
Ctrl+J (Windows)
Cmd+J (Mac)
To join two overlapping walls or individual lines, without trimming away the excess:
Select the two non-parallel walls or lines to join.
Select the command.
The selected walls/lines are joined without trimming any excess.
