Locating a resource from the drawing
Command |
Path |
Locate [resource type] in Resource Manager |
Context menu |
Use the Locate in Resource Manager command to quickly locate resources displayed in the drawing area. This command does not work for record formats or scripts.
To locate a resource from the drawing:
Select the resource (or object containing a resource, such as a rectangle with a hatch) to be located. Select the command.
The Resource Manager automatically navigates to the resource and selects it.
