Downloading from AutoTURN Online
Command |
Workspace: Path |
Get Analysis from AutoTURN Online |
Design Suite, Architect: AEC > AutoTURN Online Design Suite: Entertainment > Event > AutoTURN Online Landmark: Landmark > AutoTURN Online Spotlight: Spotlight > Event > AutoTURN Online |
Once the swept path analysis is complete, the color-coded analysis envelopes, path polyline, and data can be inserted back into the Vectorworks drawing.
To download the analysis from AutoTURN Online and place it in Vectorworks:
Do one of the following:
Select the command. (If you are not logged in to AutoTURN Online, start by Logging in to AutoTURN Online.)
If you are already in the AutoTURN Online browser, click Close and Get Analysis.
The Get Analysis from AutoTURN Online dialog box opens.
Parameter |
Description |
Saved Settings Options |
See Using saved sets to save and apply saved settings |
Drawing |
Lists all drawings saved on the AutoTURN Online servers; select the drawing to download |
View in AutoTURN Online |
Opens the selected drawing in the AutoTURN Online browser to verify the status of the drawing |
Get Analysis objects |
Determines which elements of the AutoTURN Online drawing to download into the Vectorworks file |
Vehicle swept path as polylines |
Downloads the swept path analysis; in Vectorworks, these are grouped polyline objects |
To Design Layer/In Class |
To control appearance and visibility, select the design layer and class for the downloaded items from the list of layers and classes present in the drawing, or create a new layer or class |
Vehicle profile and dimensional details |
Downloads the label with the description of the vehicle’s profile and data (must be added first in AutoTURN Online by clicking Place Vehicle Profile in Drawing) |
Previously sent geometry |
Downloads the linework that was uploaded previously, as polylines |
Previously sent background image |
Downloads the background image snapshot |
The analysis polylines and other downloaded items are inserted into the current Vectorworks file as groups.
