Drawing property lines manually
Mode |
Tool |
Tool set |
Polyline
Property Line
Design Suite: Site Planning Landmark: Site Planning and Dims/Notes |
To create property lines by drawing a polyline:
Click the tool and mode, and then select the polyline creation mode; see Creating property lines.
Click to set the starting point of the first property line segment.
Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the property line is complete. Return to the start point or simply double-click to finish creating the property line.
If you use non-arc vertices, the curve segments are approximated into arc segments.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters (see Property line parameters). The parameters can be edited later from the Object Info palette.
