Viewing saved views
To switch to a saved view:
Do one of the following:
Click Saved Views on the View bar, and select the view.
From the Saved Views palette, double-click on the view, or select the view and select Run from the Utility Menu.
To open the Saved Views palette, select Window > Script Palettes > Saved Views.
From the Navigation palette (Design Suite product required), double-click on the view, or select the view and select Activate or Activate in New Pane from the Utility menu. The Activate in New Pane command opens a floating pane to display the saved view.
From an active saved view, press the arrow key combination set for Switch Saved View (see Vectorworks preferences: Edit pane) to scroll to the next or previous saved view. For users with a Design Suite product, the saved views scroll in the current sort order in the Navigation palette. For users without a Design Suite product license, the saved views scroll in alphabetical order.
