Cutting 2D sections
Command
Path
Cut 2D Section
Model
From the Vectorworks Fundamentals workspace, the Cut 2D Section command (Vectorworks Fundamentals workspace only) cuts a 2D section, or a slice, from a 3D model without affecting the model. The slice is then placed on a new design layer. For example, to show the profile or a 2D cutaway section of an object in a mechanical 3D drawing, use this command to create the cutaway section in 2D quickly and easily, without affecting the original object.
To cut a 2D section from a 3D model:
Select the 3D model to section.
Select the command (Fundamentals workspace only).
Click to set the start of the section. Draw a line across the object to define the section, and then click to set the end of the section.
When cutting a section while the drawing is in Top/Plan view, the cutting plane (and the cut edge of the object) is perpendicular to the active layer plane. When cutting a section while in a 3D view, the cutting plane is perpendicular to the working plane.
Click on one side of the line to indicate the portion of the model to keep.
The Vectorworks program automatically creates a new design layer and places the cut 2D section on it. The original layer remains intact.
