Design SuiteCombining curtain wall frames
Mode
Tool
Tool set
Combine Frames
Edit Wall
Building Shell
To combine curtain wall frames:
Click the tool and mode.
Select the curtain wall to edit.
Click the two frames to be combined. Frames must be collinear.
At a four-way frame intersection, it may be necessary to split a perpendicular frame to be able to join collinear frames.
One frame is created. The attributes of the first clicked frame apply to both frames once they are combined.
Editing curtain wall frames and panels
