Constrain parallel
Tool
Workspace: Tool set
Constrain Parallel
Fundamentals, Design Suite, Architect, Spotlight: Dims/Notes
Landmark: Basic
Multiple constraint tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Constrain linear objects to be parallel to one another. If one object is moved, the other constrained object moves to remain parallel to the first object. If the lines aren't parallel when you place the constraint, the first line moves to become parallel to the second line.
To constrain linear objects to be parallel:
Click the tool.
Click a line or line segment to constrain.
Click a second line or line segment to create the constraint.
Green parallel constraint indicators are drawn around the two lines.
