ConnectCADPresenting to clients
If you used the ConnectCAD template, it includes three sheet layers: Schematics, Rack Elevations, and Rack 3D Layouts. These sheet layers already contain viewports which automatically display the associated design layer correctly for presentation. You can edit the scale, rendering, annotations, and so on, as needed. Title block borders are already present and ready to customize. If you create a single, multi-page PDF with the Publish command, arrow circuits become hyperlinks that allow you to navigate from one end of the circuit to the other.
In addition, use sheet layers and viewports to create Top/Plan and model views of the cable layout, to show the electrician or cable installation crew where the cables need to go within the physical model.
Create riser sheets and cabling diagrams for the installer crew and the electricians.
Along with the worksheets which report the necessary components, quantities, and other parameters, you have everything you need to present the final project to your client.
Creating sheet layer viewports
Customizing ConnectCAD objects
Creating model views
Creating a riser sheet
Creating a cabling sheet
Creating ConnectCAD reports
Viewport properties
Creating title block borders
