Design SuiteBevel gears
Mode
Tool
Workspace: Tool set
Bevel Gears
Design Suite, Architect, Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
The Bevel Gear tool and Bevel Gear - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
A bevel gear set consists of a gear and pinion.
To insert a bevel gear:
Click the tool and mode.
Parameter
Description
View
(2D only)
Select the 2D view
Value to Use
Select either Diametral Pitch or Module, and then enter the relevant parameter
Diametral Pitch
Enter the diametral pitch
Module (mm)
Enter the module
Shaft Angle (deg.)
Enter the shaft angle in degrees
Face Width
Enter the face width
Configuration
Select to use the gear parameter values for only the gear, only the pinion, or for both the gear and the pinion; this can also be used to create miter gears
Gear Properties
Specify the parameters to draw the gear
No. of Teeth
Enter the number of teeth
Pitch Dia. (Ref.)
Displays the pitch diameter based on the diametral pitch and number of teeth
Mounting Distance
Enter the distance from the back of the gear to the pitch apex
Hub Diameter
Enter the hub diameter
Hub Projection
Enter the hub projection, for styles with a projected hub
Bore Diameter
Enter the bore diameter
Key Type
If the gear includes a keyway, select keyway shape (with ASME-recommended sizes), or select Custom size
Kwy Width/Height
For custom keyway sizes, enter the keyway width and height
Recess
If the gear has a recess, enter the recess value
Fillet Radius
Enter the fillet radius of the hub
Pinion Properties
For pinion only or gear and pinion configurations, specify the pinion parameters
No. of Teeth
Pitch Dia. (Ref.)
Mounting Distance
Enter the distance from the back of the pinion to the pitch apex
Hub Diameter
Hub Projection
Bore Diameter
Key Type
If the pinion includes a keyway, select keyway shape (with ASME-recommended sizes), or select Custom size
Kwy Width/Height
Recess
If the pinion has a recess, enter the recess value
Fillet Radius
Show Pinion at Left
(2D only)
Displays the pinion on the left side of the bevel gear
Draw Center Lines
(2D only)
Draws the bevel gear with center lines
Show Teeth
(3D only)
Draws the bevel gear with teeth
Spiral Angle (Deg.)
(3D only)
Draws a 3D spiral bevel gear; specify the spiral angle degrees for the teeth
