Design SuiteClevis pins
Mode
Tool
Tool set
Clevis Pin
Fasteners
Multiple clevis pin tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a clevis pin:
Click the tool and mode.
Parameter
Description
Size
Select the clevis pin size
Use Standard Length
(inch only)
Automatically adjusts the length to the recommended standard length per ASME standards; deselect to enter a custom length value
Pin Type
(metric and DIN only)
Specify the pin type for metric and DIN clevis pins
Length
For a custom length value, deselect Use Standard Length (inch) or Use Standard Length Increments (metric and DIN) and enter the desired length
Head Style
Select the head style
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the clevis pin with center line(s)
Automatically adjusts the length to the nearest increment based on standard sizes; deselect to enter a custom length
