Design SuiteSpur gears
Mode
Tool
Workspace: Tool set
Spur Gear
Hub
Design Suite, Architect, Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple spur gear, spur gear rack, and hub tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a spur gear:
Click the tool and mode.
If you inserted a 3D spur gear, click the Hub - 3D tool from the Machine Components tool set to insert a 3D hub. Place the hub in the drawing and set the default properties, if prompted.
Parameter
Description
Pitch Diameter
Specify the pitch diameter
Number of Teeth
Enter the number of teeth
Pressure Angle
Enter the pressure angle
Diametrical Pitch (Ref.)
Displays the diametrical pitch (for reference only)
Module (mm) (Ref.)
Displays the module (for reference only)
Outside Dia. (Ref.)
Displays the outside diameter (for reference only)
Root Dia. (Ref.)
Displays the root diameter (for reference only)
Tooth Profile
Select the type of tooth profile
Face Width
Enter the width of the gear face
Helix Angle
(3D only)
Indicate the 3D spur gear helix angle
Hole Diameter
(3D only)
Indicate the hole diameter for the 3D spur gear; when including a hub 3D object in the drawing, adjust the spur gear hole diameter and hub outside diameter to fit together
Draw Recess
(2D only)
To draw a recessed web, select Draw Recess and specify the 2D parameters
Web Thickness
Enter the web thickness
Recess Diameter
Enter the recess diameter
Recess Corner Radius
Enter the recess corner radius
Recess Fillet Radius
Enter the recess fillet radius
Draw Hub
(2D only)
Draws a hub
Hub Diameter
Enter the hub diameter
Hub Projection
(Left/Right)
Specify the amount of projection for the hub on both the left and the right; a negative value indicates that the hub face is recessed
Hub Corner Radius
Enter the hub corner radius
Hub Fillet Radius
Enter the hub fillet radius
Draw Bore
(2D only)
Draws a bore
Bore Diameter
Enter the bore diameter
Keyway
If a keyway is present, select the square, rectangular, or custom size; the square and rectangular selections apply the ASME-recommended size based on the bore diameter
Width/Height
For custom keyway sizes, enter the width and height values of the keyway
Web Configuration
(2D only)
Select the web configuration and then specify the 2D parameters, if any. When Holes is selected, hole size can be specified as a percentage or diameter value.
Number
Indicate the number of holes or spokes for the gear (does not apply to Plain web configurations)
Size (10–100%)
For Holes (Percent) and Spokes web configurations, enter the percentage of the recess opening occupied by the holes or spokes
Center Distance
When Holes is selected for the web configuration, specify the distance between the hole centers
Hole Diameter
When Holes is selected for the web configuration, indicate the size of the holes
View
(2D only)
Select the 2D view
Show Center Lines
(2D only)
Draws the 2D gear with center lines
Spur gear racks
