Bearings
Ball bearings
Mode |
Tool |
Workspace: Tool set |
Modes for The Symbol Insertion tool |
Ball Bearing
Design Suite, Architect, Spotlight: Machine Components Landmark: Add tool to workspace |
Multiple ball bearing, roller bearing, and needle bearing tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a ball bearing:
Click the tool and mode.
Parameter |
Description |
Bearing Type |
Select from a variety of single ball or double ball radial and angular bearings |
Single Row, Radial |
Single Row, Angular |
Double Row, Radial |
Double Row, Angular |
Inside Diameter |
Specify the inside diameter of the bearing |
Outside Diameter |
Specify the outside diameter of the bearing |
Width |
Enter the width of the bearing |
View (2D only) |
Select the 2D view
Show Detail (2D only) |
Indicate whether to display a detailed 2D view of the bearing
Show Center Line (2D only) |
Draws the bearing with center lines |
Section (3D only) |
Draws a section of the bearing |
Highlight Rollers (3D only) |
Highlights the rollers within the bearing in black |
