Tapered roller bearings
Mode |
Tool |
Workspace: Tool set |
Modes for The Symbol Insertion tool |
Tapered Roller Bearing |
Design Suite, Architect, Spotlight: Machine Components Landmark: Add tool to workspace |
Multiple ball bearing, roller bearing, and needle bearing tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a tapered roller bearing:
Click the tool and mode.
Parameter |
Description |
Bearing Type |
Select from a variety of bearing types
Inside Diameter |
Specify the inside diameter of the bearing |
Outside Diameter |
Specify the outside diameter of the bearing |
Width of Inner Ring |
Enter the width of the inner ring |
Width of Outer Ring |
Enter the width of the outer ring |
Space Between Rows |
Enter the space between rows |
Inner Ring Projection |
Specify the projection distance of the inner ring |
View (2D only) |
Select the 2D view
Show Retainers |
Displays the bearing with retainers; Show Detail must also be selected in order to view the retainers in 2D bearings |
Show Detail (2D only) |
Indicate whether to display a detailed 2D view of the bearing (including balls and/or retainers)
Show Center Line (2D only) |
Draws the bearing with center lines |
Section (3D only) |
Draws a section of the bearing |
Highlight Rollers (3D only) |
Highlights the rollers within the bearing in black |
