Angle between two object edges or faces
Mode |
Tool |
Tool set |
Shortcut |
Edges
Angular Dimension
Dims/Notes |
. (period) |
To dimension the angle between the edges or faces of two objects:
Click the tool and modes, and then select a Standard (dimension standard) and the Units.
Click the edge or face of the first object.
A preview line displays.
Click the edge or face of the second object.
An angular dimension preview displays.
To select a different angle—for example, spanning the opposite direction—move the cursor until the preview displays the desired angle.
Click a third time to define the radius of the dimension.
