Inserting a stage deck
Mode |
Tool |
Tool set |
Bottom Insertion Point
Top Insertion Point
Stage Deck
Event |
The Stage Deck tool inserts rectangular and rounded portable stage structures into a drawing. The type, shape, size, appearance, and presence of railings can be customized. Place several stage decks to create a large stage area.
Mode |
Description |
Place the first stage deck into the drawing using this mode |
Top Insertion Point
Once the first stage has been placed, switch to this mode to easily align the stage deck with existing ones |
Alignment modes |
Select the alignment mode (see The Symbol Insertion tool) |
Automatic Numbering
When toggled on, enables automatic numbering as objects are placed |
Automatic Numbering Preferences
Sets the automatic numbering preferences |
Preferences
Sets the default parameters that are used for each stage deck |
To insert a stage deck:
Click the tool and insertion mode, and then click the alignment mode.
Click to place the object in the drawing, and click again to set the rotation.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette. Some information from parameters can also be placed on the drawing using the Text Options.
Parameter |
Description |
Deck Shape |
Creates a rectangular or round stage |
Height |
Specifies the overall stage height |
Depth/Width (rectangular shape) |
Specifies the dimensions of a rectangular stage deck |
Radius/Diameter/Sweep Angle (round shape) |
Specifies the size of a round stage deck |
Top Surface Area |
Displays the calculated surface area of the stage |
Structure |
Select the type of stage construction, from simple to complex
Deck Details |
Hide Deck |
For the Legs-Braced structure types, hides the deck and shows the braced leg supports only |
Top Thickness |
Sets the thickness of the deck. The thickness of the deck cannot be set for Border and Simple stage deck structures. |
Top Color/Texture |
Displays the texture or color selected in the 3D Options |
Trim Height |
Sets the height of the trim around the stage |
Trim Color/Texture |
Border Color/Texture |
For the Border structure type, displays the texture or color selected in the 3D Options |
Leg/Structure Details |
Diameter |
For structure types with legs, sets the diameter of the leg supports |
Profile |
For structure types with legs, select a round, square, or octagonal shape for the legs |
Color/Texture |
Reference Spacing |
For Legs-Basic and Legs-Braced, sets an approximate spacing value for the legs; the exact spacing is determined automatically by evenly dividing the length of the deck |
Leg Total |
For structure types with legs, displays the number of legs |
Additions (rectangular shape) |
For the Legs-Basic and Legs-Braced structure types, select to add casters, blocks, or none |
Wheel Color/Texture |
Railing Details |
All railing bars are automatically evenly spaced |
Front/Back/Left/Right (rectangular shape) |
Select the type of railing to add to each side of the stage deck
Start Radius/ End Radius/ Arc (round shape) |
For round deck shapes, select the type of railing to add to each side of the stage deck. Rounds decks are limited to Straight, Toe, or Straight + Toe railing types.
Height |
Sets the height of the top of the railing |
Add’l Horiz. Bars (Straight and Straight + Toe) |
Specifies the number of additional horizontal bars to add to the railing |
Add’l F/B Uprights (rectangular shape) |
For rectangular deck shapes, adds additional vertical bars to the front and back railing |
Add’l L/R Uprights (rectangular shape) |
For rectangular deck shapes, adds additional vertical bars to the left and right railing |
Add’l Radii Uprights (round shape) |
For round deck shapes, adds additional vertical bars to the start and end radius railing |
Add’l Arc Uprights (round shape) |
For round deck shapes, adds additional vertical bars to the arc railing |
Profile |
Select a round, square, or octagonal shape for the railing |
Color/Texture |
Specifies the appearance of applicable deck elements in 3D views. The 3D Options dialog box opens. For each available portion of the stage, either select the color from the Color list, or select Custom Texture and then click the current custom texture to open the Resource Selector; double-click a resource to select it. The Object Info palette displays the color or texture selections in the relevant section. The appearance of Simple stage decks is set from the Attributes palette. |
Location, Position, Unit, Purpose, Set Cart ID, Brand, Model, Vendor, Cost, Note |
Adds information which can be placed on the drawing or used for reporting |
Text Options |
Opens the Text Options dialog box, to enable the display and format the text of labels |
Default Text Positions |
Restores text labels to their default positions |
Opens the Classes dialog box, to specify class naming for the various portions of the stage deck. This allows portions of the stage deck to be set to visible, grayed, or invisible. Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Stage Deck Class> to place the stage deck element in the same class as the stage deck. Class Prefix: Specifies an optional default root class naming standard for all stage deck parts; click Assign Default Classes With Prefix to begin all stage deck class names with the prefix, so that they are sorted together. Assign Default Classes With Prefix: Sets the class names for all stage deck elements to the standard, using the Class Prefix if there is one. Stage deck elements: For each portion of the stage deck, including the loci that represent the stage deck legs in the Deck Only Structure, specifies the class name standard; the class names shown here are applied to the elements. |
Update |
Updates the object when changes have been made to the Object Info palette parameters |
Equipment Subparts |
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists. The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane. |
Equipment Virtual Parts |
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette. |
Edit Virtual Parts |
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts |
Assign Sources |
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory |
