SpotlightInserting an LED screen
Mode
Tool
Tool set
LED Screen
Audio/Video
The Light-emitting Diode (LED) object simulates a variety of low-resolution LED screens in arrays on a base structure.
To insert an LED screen or array:
Click the tool and the insertion modes.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette. Some information from parameters can also be placed on the drawing using the Text Options.
Parameter
Description
Module Shape
Select a shape for the screen modules in the array
Tile Flat: creates rectangular-shaped modules
Tile Cap: creates rectangular-shaped modules with frosted caps
Disk Flat: creates round modules
Disk Cap: creates round modules with frosted caps
Tube: creates tube-shaped modules
Dome: creates dome-shaped modules
Width
Specifies the width of each module in the array
Height
For tiled arrays, sets the height (length) of each module in the array
Brand
Specifies the screen's brand
Model
Sets the screen's model
Cap Depth
For capped arrays, sets the depth of each module's cap
Tube Orientation
For tube arrays, specifies whether the tubes are oriented vertically or horizontally
Length
For tube arrays, sets the length of one of the tube modules
Build Array Based On
Module counts and spacing
Sets the size of the entire LED array based on the number of modules specified in the horizontal and vertical directions, as well as the horizontal and vertical spacing distance set between the modules
Overall dimensions and spacing
Sets the size of the entire LED array based on the specified array width and height, as well as the horizontal and vertical spacing between the modules; the screen count is automatically calculated
Overall dimensions and module counts
Sets the size of the entire LED array based on the specified array width and height, as well as the number of modules specified in the horizontal and vertical directions; the spacing is automatically calculated
Array Width/Height
Specifies the width and height of the entire LED array, when the array is based on overall dimensions
Horizontal/Vertical Count
Specifies the number of modules in the horizontal and vertical directions, when the array is based on the module counts
Add Half Modules
Select to add half modules to the array or none
Module Total
Displays the total calculated number of modules in the array
Half-Module total
Displays the total calculated number of half modules in the array
Horizontal/Vertical Spacing
Specifies the spacing between modules in the horizontal and vertical directions, when the array is based on spacing parameters
Width/Height (Calc.)
Displays the calculated width and height of the array, when determined by module count and spacing
H/V Spacing (Calc.)
Displays the calculated module spacing in the horizontal and vertical directions, when the array is determined by the overall dimensions and module counts
H/V Count (Calc.)
Displays the total number of modules in the horizontal and vertical directions, when the array size is determined by the overall dimensions and module spacing
Pixels Per Module H/V
Specifies the number of horizontal or vertical pixels for each module (for calculation purposes only; does not affect the module display)
Array Size (Pixels)
Displays the total number of pixels for the entire LED array
Raster Information
Specifies the raster image
Array Aspect
Specifies the aspect ratio of the array
Secondary Units
Select an additional unit of measurement to calculate the array size
Array Size (Secondary Units)
Displays the selected secondary unit of measurement for the array size
Base Structure
Select a base structure for the array; modify the appearance of the structure by selecting Class LED Array Parts and then editing the structure class
Blocks: creates a structure of individual blocks bases for each module
Frame: creates a single frame for the entire array
Curtain: creates a single background for the array
Web: creates a webbed structure behind the modules
Vert. Strips: places the LED modules in vertical columns
Horiz. Strips: places the LED modules in horizontal rows
None: does not create a base structure for the array; displays only the LED modules
Width
Specifies the width of blocks, vertical or horizontal strips, or the entire frame
Height
Specifies the height of blocks, vertical or horizontal strips, or the entire frame
Depth
Specifies the depth of blocks, vertical or horizontal strips, or the entire frame
Side Edge Miter
Select the edge(s) of the outer row tiles to be mitered (none, left, right, or both)
Horizontal Inset
Sets the horizontal distance (margin) between the horizontal edge of the base structure and the array
Vertical Inset
Sets the vertical distance (margin) between the vertical edge of the base structure and the array
Pleat Width
For curtain or web structures, specifies the pleat width of the curtain (2D only for web structures)
Pleat Depth
For curtain or web structures, specifies the pleat depth of the curtain (2D only for web structures)
Webbing Width
For web structures, sets the width of the connecting web segments
Single Module Wattage/Total Array Wattage
Enter the required wattage for a single module, and the total array wattage will be calculated; if either of these parameters are changed, the other parameter will automatically update
Weights
Reference
Select whether to show the weight parameters for a single module or all modules
Single Module
Specifies the weight for a single module when the reference is a single module
Half-Module
Specifies the weight for a half module when the reference is a single module
All Modules
Displays the weight for all modules when the reference is for all modules
Hardware
Specifies the weight of the hardware
Total
Displays the total weight of the screen array
Distributed
Displays the distributed weight of the screen array
Tilt
Specifies the tilt angle of the screen array
Simple 3D
Creates a single textured 3D polygon to represent the screen modules; this speeds rendering when each module does not need to be shown individually
Show coverage zone (2D only)
Indicates the viewing area based on the screen size; observers within the area should be able to see the screen
Settings
Zone Reference
Calculates the coverage zone based on screen width, height, or diagonal measurement
Max Horiz. Angle/ Max Vert. Angle
Indicates the maximum viewing angle of the screen, horizontally and vertically, relative to dead-on
Viewing Height
Enter the height of the average viewer when watching (likely, a seated height)
Near Multiplier
Specifies the multiplier of the reference dimension to determine the extent of the near coverage zone
Far Multiplier
Specifies the multiplier of the reference dimension to determine the extent of the far coverage zone
Array Image
Displays the name of the current screen image
Edit Array Image
Opens the Edit Aray Image dialog box; see Assigning an image, video, or input
Projector 1/Projector 2 Power and Signal Details
Circuit Number
Indicates the circuit number where the video screen is plugged in
Circuit Name
Specifies the name of the bundled circuit group
Source
Specifies the source information
Drive Line
Indicates information about the drive line feeding the signal to the video screen
Input
Specifies the input information
Frame Rate
Specifies the frame rate information
Resolution
Specifies the resolution
Location, Position, Unit, Purpose, Vendor, Cost, Note
Adds information which can be placed on the drawing or used for reporting
Row
Enter notes about the module row, when the array is based on module counts with a horizontal/vertical count of 1 (respectively)
Column
Enter notes about the module column, when the array is based on module counts with a horizontal/vertical count of 1 (respectively)
Text Options
Opens the Text Options dialog box, to enable the display and format the text of labels
Default Text Positions
Restores text labels to their default positions
Classes
Opens the Classes dialog box, to specify class naming for the various portions of the LED screen. This allows portions of the LED screen to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <LED Screen Class> to place the LED screen element in the same class as the LED screen.
Class Prefix: Specifies an optional default root class naming standard for all LED screen parts; click Assign Default Classes With Prefix to begin all LED screen class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all LED screen elements to the standard, using the Class Prefix if there is one.
LED screen elements: For each portion of the LED screen, specifies the class name standard; the class names shown here are applied to the elements.
Update
Updates the object when changes have been made to the Object Info palette parameters
Load Information
An LED screen is considered a distributed load in Braceworks calculations; if the screen is inserted parallel to a rigging object, it is considered to be a load on that structure. Load information is used for Braceworks calculations and reports (Braceworks required).
Include in calculations
Includes the LED screen in Braceworks calculations; deselect to exclude the object from participating in structural calculations
Load Group Name
The load category is always Video for LED screen objects
Load ID
Enter a unique ID for the load for informational use in reports
Load Name
Identifies the object in load calculations
Distributed Weight
Enter the distributed weight of the LED screen object; changes here also affect the Total Weight value
Total Weight
Enter the total weight of the object
Position
Displays the name of the associated rigging object, if the LED screen is attached.
For methods to attach loads, see Making the attachment.
Equipment Subparts
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists.
The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane.
Equipment Virtual Parts
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette.
Edit Virtual Parts
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts
Assign Sources
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory
Formatting video screen object labels
Concept: Attaching loads to rigging objects
Managing and reporting equipment lists
