Design SuiteInserting shelving units
Mode
Tool
Workspace: Tool set
Shelving Unit
Design Suite, Architect, Spotlight: Furn/Fixtures
Landmark: Building Shell
The Shelving Unit tool provides access to a variety of standard configurations available from the Resource Manager, in addition to individual objects created using the tool. The tool can be used to create your own style resources (see Concept: Plug-in object styles).
In addition to these common shelving units, Vectorworks offers the flexibility of creating custom cabinets (see Creating custom cabinets).
To insert a shelving unit:
Click the tool and mode.
Do one of the following:
Click Shelving Unit Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Parameter
Description
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object.
Editing a style changes all instances in the file that use the style.
Hide Style Parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Flip
If the object is in a wall, click to flip the object orientation
Set Position
If the object is in a wall, click to activate the Move by Points tool in Reference Point mode and move the object by a specified distance from a reference point
Type
Select the unit type
Config
Select the unit configuration
Height/Width/Depth
Enter the unit’s height, width, and depth
Bottom
Enter the height of the bottom shelf
Shelves
Enter the number of shelves; the shelves are spaced evenly between the bottom shelf and the top of the unit
Thickness
Enter the thickness of the cabinet material
Back
Encloses the back of the unit
Back Finish/Shelf Finish/Bracket Finish
To control appearance and visibility, select a class for each component from the list of classes present in the drawing, or create a new class. Select <Shelving Unit Class> to place the component attributes in the same class as the shelving unit object.
Facing Board
For straight units, select whether to add a facing board
Board Offset
Enter the size of the facing board offset from the front of the unit
Click on the drawing to place the object, and click again to set the rotation.
Optionally, create a style resource from the object (see Standard plug-in object styles without catalog options).
Symbols within a wall
