Importing Parasolid X_T
Command |
Path |
Import Parasolid X_T (3D only) |
File > Import |
The Vectorworks program can import 3D Parasolid X_T objects, including NURBS curves, NURBS surfaces, and solids; solids are imported as generic solids.
To import a Parasolid X_T file:
Select the command and then the file to import.
Alternatively, click the file to import and drag it into an open Vectorworks file.
The Import Parasolid X_T Options dialog box opens.
Select Import as symbol to import the file contents as a symbol definition in the Resource Manager; for more information, see Resource Manager and Concept: Vectorworks symbols.
