SpotlightRotating lighting devices
There are several ways to rotate lighting devices; see Rotating objects for an overview and links to specific methods. All attached accessories rotate with the lighting device. The relevant properties automatically update in the Object Info palette.
To rotate lighting devices:
Rotate the devices interactively with the Rotate tool. Only the standard 2D and 3D rotation modes are available.
Use the Rotate commands to flip the devices or rotate them 90°. The devices can rotate individually or as a group; see Preset rotation angles
Edit the X/Y/Z Rotation values on the Object Info palette.
