SpotlightUsing photometric threshold settings
Vectorworks' photometric grid and photometer calculate and display the illumination values at the elevation point. The values are displayed in either foot candles (Imperial) or lux (Metric), depending on the units selected in File > Document Settings > Units. The pen color of each indicator provides a visual cue of the light intensity according to defined ranges, which are specified here.
To specify threshold settings:
From the Object Info palette of either a photometric grid or photometer, click Threshold Settings.
The Threshold Settings dialog box opens.
Parameter
Description
Color Shown for Zero Value
Click the color box to select a color that indicates 0 (zero) illumination
Color Shown Below Lower Threshold
Click the color box to select a color that indicates illumination values below the lower threshold limit
Lower Threshold
Specify the lower threshold illumination value
Color Shown Between Lower and Upper Threshold
Click the color box to select a color that indicates illumination values between the lower threshold and the upper threshold limit
Upper Threshold
Specify the upper threshold illumination value
Color Shown Above Upper Threshold
Click the color box to select a color that indicates illumination values above the upper threshold limit
To evaluate the illumination values at different heights, change the elevation of the photometric object in the Object Info palette.
Obtaining photometric data
