Specifying callout or keynote legend bubble shadow settings
To specify bubble shadow edge and fill attributes:
In the Callout Preferences dialog box, click Shadow Settings, or in the Object Info palette for a selected callout or keynote legend, click Bubble Shadow Settings.
To activate this option, Bubble Style must be set to a style other than None, Bracket, ISO, or Vertical Accent Bar, and Bubble Shadow must be selected.
The Bubble Shadow Settings dialog box opens. Set the parameters; the bubble shadows in the drawing area immediately preview the settings.
Parameter |
Description |
Draw Bubble shadow edge/Draw Bubble shadow fill |
Draws an edge/fill for the shadow |
Use object's pen color |
Uses the callout object's or keynote legend object's pen color |
Use custom pen color |
Uses a custom pen color; select the color |
