Moving objects in 3D space
Command |
Path |
Shortcut |
Move 3D |
Modify > Move |
Ctrl+Alt+M (Windows) Cmd+Option+M (Mac) |
To move an object in 3D space by command:
Select the object to move.
Select the command.
The Move 3D Selection dialog box opens.
Parameter |
Description |
Layer Plane |
Select the X, Y, Z (layer plane) coordinate system |
X, Y, Z Offset |
For layer plane coordinates, specify the distance to move the object |
Working Plane |
Select the X’, Y’, Z’ (working plane) coordinate system |
X’, Y’, Z’ Offset |
For working plane coordinates, specify the distance to move the object |
The object is moved in 3D space according to the criteria specified.
