Importing an adjacency matrix spreadsheet
Command |
Path |
Import Adjacency Matrix |
Design Suite, Architect: AEC > Space Planning Landmark and Spotlight: Add command to workspace (see Customizing workspaces) |
To import an adjacency matrix:
Ensure that the file to be imported is a tab- or comma-delimited file (.txt or .csv).
Select the command to open the Import Adjacency Matrix dialog box. Specify the adjacency matrix file import options.
Parameter |
Description |
External Filename |
Enter the name of the adjacency matrix file or click Browse to specify its location; a sample file is specified by default |
Header Rows |
Specifies the number of rows in the spreadsheet that do not include space or space relationship information |
Row Spacing |
Set this to 0 (zero) if there is a space name on every row or set this to 1 if there is a space name on every other row in the drawing file |
Field Delimiter |
Specifies the delimiter that is used to separate fields for the spreadsheet |
Column Numbers and Preview |
Specifies the columns to include in the adjacency matrix as well as their position |
Department |
Includes department number information; specify its column number |
Space |
Includes area name information; specify its column number |
Area |
Includes the space area information; specify its column number |
Relationships |
Includes the space relationship information; specify its column number |
Preview |
Displays the data in the selected columns |
If this is the first time an adjacency matrix, stacking diagram, spaces, or space links are placed in the file, a properties dialog box opens for each type of object. Set the default parameters. The parameters can be edited later from the Object Info palette.
