Design SuiteSketching with hidden line rendering
The default document sketch style can be applied to hidden line, dashed hidden line, and final shaded polygon rendering modes.
To apply a sketch style to hidden line rendering:
Select View > Rendering > Line Render Options, or select the command from the Current Render Mode menu on the View bar.
The Line Render Options dialog box opens.
Select Sketch Hidden Line Results, and select the sketch style from the list.
The selected sketch style is applied in hidden line, dashed hidden line, and final shaded polygon rendering modes.
To apply a sketch style to the hidden line rendering of a sheet layer viewport:
Select the viewport, and then select a hidden line rendering mode from the Rendering list in the Object Info palette.
Click Render Settings.
The Hidden Line Render Settings dialog box opens.
Sketch rendering
Rendering modes
