Creating circles
The Circle tool has six modes and the Push/Pull mode.
Mode |
Description |
Radius
Defines the circle by its radius |
Diameter
Defines the circle by its diameter |
Circle by Three Points
Defines the circle by its circumference |
Circle from Three Lines
Defines the circle by making it tangent to two or three selected lines |
Point and Center
Defines the circle by a point on its circumference and then its center |
Tangent and Center
Defines the circle by defining a tangent to the circle and then its center |
Push/Pull (3D views only)
Instantly extrudes the circle after creation; see Push/Pull mode of planar tools |
Push/Pull Combine (available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged |
To create a NURBS curve, draw a circle and then select Modify > Convert > Convert to NURBS.
Circle by radius
Mode |
Tool |
Tool set |
Shortcut |
Radius
Circle
Basic |
6 |
To create a circle by radius:
Click the tool and mode.
Click to set the center of the circle.
Move the cursor to the desired radius and click to set the radius of the circle.
Circle by diameter
Mode |
Tool |
Tool set |
Shortcut |
Diameter
Circle
Basic |
6 |
To create a circle by diameter:
Click to set the first point on the circle diameter.
Move the cursor to the desired diameter and click to set the diameter of the circle.
Circle by three points
Mode |
Tool |
Tool set |
Shortcut |
Circle
Basic |
6 |
To create a circle by three points:
Move the cursor and click to set the second point on the circle and click again to set the third point on the circle.
Circle from three lines
Mode |
Tool |
Tool set |
Shortcut |
Circle
Basic |
6 |
To create a circle tangent from three lines:
Click to select the three lines or linear segments to which the circle will be tangent. Each line is highlighted as it is selected. The lines (or their extensions) must intersect in at least two places.
When the third line is selected, a preview of a tangent circle displays where the cursor is currently located. You can create circles tangent to two or three lines. In places where only two lines intersect, the size of the circle is controlled by the cursor location. Move the cursor until the desired tangent circle displays, and then click to set the circle.
Circle by point and center
Mode |
Tool |
Tool set |
Shortcut |
Point and Center
Circle
Basic |
6 |
To create a circle by point and center:
Click to set the first point on the circumference of the circle.
Move the cursor to the center of the circle and click to set the radius of the circle.
Circle by tangent and center
Mode |
Tool |
Tool set |
Shortcut |
Tangent and Center
Circle
Basic |
6 |
To create a circle by tangent and center:
Click to set the first point on the line tangent to the circle.
Click to set the second point on the line tangent to the circle, defining the tangent line.
Move the cursor to define the radius perpendicular to the tangent. Click to set the radius of the circle. It is not necessary to click the center point; click anywhere along an axis parallel to the tangent. This allows you to set the radius based on other geometry, if desired.
