Stitching and trimming surfaces
Command |
Path |
Stitch and Trim Surfaces |
Model > 3D Power Pack |
The Stitch and Trim Surfaces command creates a generic solid from several intersecting surfaces (including NURBS surfaces or solids such as extrudes or sweeps).
This command may not be able to manipulate certain types of surface geometry.
To stitch and trim intersecting surfaces:
Select the intersecting surfaces. The surfaces must enclose a volume.
Select the command.
The surfaces enclosing the volume are stitched together and then trimmed, resulting in one or more generic solids.
Curved NURBS surface objects are transformed into a generic solid object. The enclosed volume is created by an extrude beneath the NURBS objects and by the rectangular NURBS surface that intersects them.
