Architect or LandmarkCreating stepped walls
Command
Workspace: Path
Create Stepped Wall
Design Suite, Architect: AEC
Landmark: Landmark > Architectural
Stepped walls add wall peaks to existing walls created with the Wall tool. The existing wall can be a single wall or a chain of multiple wall segments that are L-joined to each other. Stepped walls can have a constant rise at each interval, or conform to underlying terrain with a variable rise, such as free-standing landscape walls or fences.
To create a stepped wall:
Select the wall or multiple, L-joined walls.
Select the command.
The Create Stepped Wall dialog box opens. Set the stair parameters.
The options available depend on the selected Step Style (even steps or terrain steps). If the parameters are set so that the steps are uneven, the top step is truncated.
Parameter
Description
Even Steps
Creates a stepped wall with a constant rise and wall peaks at even intervals
Preview
Previews the selected configuration
Total Length
Displays the total length of the stepped wall to be created
Number of Steps
Displays the total number of steps to be created
Calculator
The steps are created based on three parameters: step length, step rise, and total rise. Based on the entry of two of these parameters, the third is automatically calculated. Click to place the calculator at the parameter that should be automatically calculated, and enter the values for the other two parameters.
Step Length
Sets the length of one step
Step Rise
Sets the rise of one step
Total Rise
Specifies the total rise value
Apply Steps to
Steps can be applied to either the top or bottom of the wall, or both
Top of Wall
Steps apply to the top of the wall
Horizontal Offset
Specifies the horizontal offset of the top steps; positive values move the steps to the left, while negative values move them to the right. This allows the last step to be shorter or longer, for example.
Bottom of Wall
Steps apply to the bottom of the wall
Horizontal Offset
Specifies the horizontal offset of the bottom steps; positive values move the steps to the left, while negative values move them to the right
Reverse Direction
Sets whether steps should be started from the beginning of the wall (option is deselected) or end of the wall (option is selected)
Terrain Steps
Total Length
Number of Steps
Step Length
Vertical Offset
Specifies the offset distance from the terrain surface; an offset of zero keeps the steps at the surface, while a positive value raises them above the surface
Apply Steps to
Top of Wall
Applies steps to the top of the wall, mirroring the terrain
Horizontal Offset
Bottom of Wall
Terrain steps are always applied to the bottom of the wall, since the steps follow the terrain
Horizontal Offset
Specifies the horizontal offset of the bottom steps; positive values move the steps to the left, while negative values move them to the right.
Place Steps Above Terrain
The steps are reversed so that they are above the terrain
The Send to Surface command can be used on walls; it sets the bottom Z value at the start of the wall to the existing terrain surface (see Sending objects to the surface).
Creating walls
L wall joins
Creating retaining walls
