Reporting site model volume
Command |
Workspace: Path |
Create Site Model Volume List |
Design Suite, Architect: AEC > Terrain Landmark: Landmark |
The individual cut and fill calculations for a site model can be listed in a report for verification.
To list site model volume:
Select the site model to analyze. Only one site model can be analyzed at a time.
Select the command.
The Create Site Model Volume List dialog box opens. On the Columns tab, select the columns of site model data to include in the report.
Parameter |
Description |
Available Columns |
Lists the columns that can be selected for inclusion in the report |
Selected Columns |
Lists the columns to be included in the report; to change the list order, use the cursor to drag and drop the items to move in the # column. |
Add > |
Adds one or more selected items from the available list to the end of the Selected Columns list |
Add All >> |
Adds all available columns to the end of the Selected Columns list |
< Remove |
Removes one or more selected items from the Selected Columns list |
<< Remove All |
Removes all column items from the Selected Columns list |
Column Parameters |
Triangle Index |
Creates a numeric index for each triangle that makes up the site model Triangulated Irregular Network (TIN) |
Existing Surface Area |
Lists the surface area of each triangle in the existing site model |
Proposed Surface Area |
Lists the surface area of each triangle in the proposed site model |
Projected Area |
Lists the projected area of the common (existing and proposed) site model triangles |
Existing Volume |
Lists the volume of each triangle (extruded to the existing site model’s Minimum Elevation plus its Datum Elevation) |
Proposed Volume |
Lists the volume of each triangle (extruded to the proposed site model’s Minimum Elevation plus its Datum Elevation) |
Cut Volume |
Compares the existing and proposed volume for each triangle in the site model, and displays the extra volume present in the proposed model |
Fill Volume |
Compares the existing and proposed volume for each triangle in the site model, and displays the volume removed from the proposed model |
Net Cut & Fill Volume |
Lists the fill volume minus the cut volume for each triangle in the site model |
Total Cut & Fill Volume |
Lists the fill volume plus the cut volume for each triangle in the site model |
On the Grade Limits Modifiers tab, select the grade limits site modifiers to include in the report calculations.
Parameter |
Description |
Available Grade Limits Modifiers |
Lists the grade limit-type site modifiers in the drawing; grade limits modifiers are identified by an assigned number |
Selected Grade Limits Modifiers |
Lists the site modifiers to be included in the report calculations |
Add > |
Adds one or more selected items from the available list to the end of the Selected Grade Limits Modifiers list |
Add All >> |
Adds all available modifiers to the end of the Selected Grade Limits Modifiers list |
< Remove |
Removes one or more selected items from the Selected Grade Limits Modifiers list |
<< Remove All |
Removes all items from the Selected Grade Limits Modifiers list |
Show Modifier |
When a numbered grade limits modifier is highlighted, selects the associated site modifier in the drawing, and zooms in so the site modifier is easily identifiable |
Modifier Parameters |
Outside Grade Limits |
Includes all areas of the site model surface without any modifiers |
Grade Limits Modifier __ |
Each grade limits site modifier in the drawing is identified with a number. If you have provided a name for the site modifier on the Data tab of the Object Info palette, the name displays in parentheses |
On the Options tab, set the report output parameters.
Parameter |
Description |
Show Data for Unmodified Site Model Surface |
When selected, the report includes the entire surface of the site model. Deselect this option to exclude the unchanged surface between the existing and proposed site models from the report. |
Create Text File |
Creates a tab-delimited text file of the report, which can easily be imported into a spreadsheet program for further manipulation. Specify the name of the text file and the location to save it in. |
Create Triangle Group |
Creates a group containing subgroups of polygons and volumetric data text for each triangle that makes up the site model triangulated network. For complex site models, a significant amount of information is displayed; adjust text size of the entire selected group with the Text > Size command. |
Create Worksheet |
Adds a Volume List worksheet containing the volume data to the current file |
