ArchitectInserting escalators
Tool
Tool set
Escalator
Building Shell
The Escalator tool provides access to a variety of standard escalator types available from the Resource Manager, in addition to individual objects created using the tool. The tool can be used to create your own escalator styles (see Concept: Plug-in object styles).
To insert an escalator:
Click the tool.
Do one of the following:
Click Escalator Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Parameter
Description
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object.
Editing a style changes all instances in the file that use the style.
Hide Style Parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Height
Height
Directly sets the desired height of the escalator. When the escalator height is determined manually by this method, the Top Bound property of the escalator is automatically set to Layer Elevation, and the Top Offset value is modified accordingly.
When the top of the escalator is bound by the layer wall height value or by a story level, the escalator height displays automatically.
Top Bound
Sets the vertical reference that determines the top of the escalator.
The Layer Wall Height value is set by the design layer (see Setting design layer properties).
Alternatively, the top of the escalator can be bound by one of the story levels defined for the story or the story above it. By setting the top of the escalator to a level type, if the elevation of the associated story changes, the height of the escalator changes automatically to match.
Top Offset
Sets the offset of the top of the escalator from its specified top bound height
Bot Bound
Sets the vertical reference that determines the bottom of the escalator. Alternatively, the bottom of the escalator can be bound by one of the story levels defined for the story or the story below it. By setting the bottom of the escalator to a level type, if the elevation of the associated story changes, the height of the escalator changes automatically to match.
Bot Offset
For the bottom of the escalator, sets the offset from its specified bottom bound height
Type
Select a generic escalator or one of the common escalator types
Slope angle
Select from the common slope angles available for an escalator
Floor depth above
Indicates the depth of the floor-to-ceiling construction on the upper floor being serviced by the escalator; this parameter affects the size of the headroom and pit in Top/Plan view
Step width
Select a common step width configuration
Horizontal lead in
Select the number of horizontal escalator steps at the bottom of the escalator
Balustrade type
Select the type of geometry that encloses the sides of the escalator and supports the moving handrail
Section cut
Select whether to display the escalator with a section break going up or down, or without a break
Draw 3D
In 3D views, represents the escalator with a 3D polygon
Show pit
Indicates whether the extents of the minimum required pit below the escalator display in Top/Plan view
Show headroom
Indicates whether the extents of the minimum required headroom above the escalator display in Top/Plan view
Override Maximum Allowable Span
Overrides the maximum allowable length of the selected escalator type; this parameter is affected by the horizontal lead-in and slope angle values, as well as the selected escalator type
Override Maximum Height Limit
Overrides the maximum allowable floor-to-floor height of the selected escalator type; this parameter is affected by the horizontal lead-in and slope angle values, as well as the selected escalator type
Click on the drawing to place the object, and click again to set the rotation.
Optionally, create a style resource from the object (see Standard plug-in object styles without catalog options).
