Creating layers
When a new drawing is created, it automatically contains an empty design layer entitled "Design Layer-1." Add design layers to the drawing to organize it. Add sheet layers as needed for presentation. Create new design layers and sheet layers, duplicate existing layers, or import layers (and optionally, the objects they contain) from other current version files or from standard files. In Vectorworks Design Suite products, create a design layer viewport to reference design layers in other files without importing them.
To create a new layer:
Do one of the following.
On the Design Layers or Sheet Layers tab of the Organization dialog box (Tools > Organization, or Show Organization Dialog Box from the Layer Options list on the View bar), click the New button or select New from the context menu.
Click Layer Options on the View bar, and then select New Design Layer or New Sheet Layer.
Click Active Layer on the View bar, and then select New Design Layer or New Sheet Layer.
On the Shape tab of the Object Info palette, select New Design Layer or New Sheet Layer from the Layer field.
On the Design Layers or Sheet Layers tab of the Navigation palette (Vectorworks Design Suite product required), select New from the context menu or Utility Menu.
To create a new layer from an existing layer:
On the Design Layers or Sheet Layers tab of the Organization dialog box, select the layer to duplicate and then click the Duplicate button or select Duplicate from the context menu.
On the Design Layers or Sheet Layers tab of the Navigation palette (Vectorworks Design Suite product required), select the layer to duplicate and then select Duplicate from the context menu or Utility Menu.
Click Layer Options on the View bar, and then select Duplicate Active Layer.
The New Design Layer or New Sheet Layer dialog box does not open when duplicating a design layer or sheet layer. The new layer has the same settings as the duplicated layer; to edit the settings, see Setting design layer properties and Setting sheet layer properties.
From the New Design Layer or New Sheet Layer dialog box, create a new layer, or import a layer and its properties from standard or existing Vectorworks files.
Parameter |
Description |
Create a New Design Layer or Create New Sheet Layer |
Creates a new design or sheet layer. For a design layer, also enter a descriptive Name. For a sheet layer, enter a unique Sheet Number, or use the default (as in Sht-2). The Sheet Number can be displayed in drawing labels, section markers, and title block borders. Also enter a descriptive Sheet Title, which can be displayed in title block borders. |
Import Design Layers or Import Sheet Layer |
Imports layers and their attributes from standard files or from existing files. Files located in the Standards folder, as well as existing files selected previously, are displayed in the list. Select a file; the available layers and descriptions are listed beneath the file name. If a layer name in the current file matches a layer in the import file, that layer is not on the list as an import option. Select the desired layer. To select multiple layers from the import list, hold down the Ctrl (Windows) or Command (Mac) key while you click. |
Choose |
Click Choose to select a file for layer import. Files must be in the current version. |
Import Layer Objects (design layer only) |
In addition to importing the design layer structure and attributes, imports the contents of the layers; if a file has become corrupted, this is a possible way of recovering its data. If there is a naming conflict with pre-existing symbols or pre-existing layers in the current file, replace or rename the symbols or rename the layers. |
Creation Options |
Saved View Visibility (design layer only) |
Sets the visibility of the new design layer in saved views (when saved views exist in the drawing) |
Viewport Visibility (design layer only) |
Sets the visibility of the new design layer in viewports (when viewports exist in the drawing) |
Edit Properties After Creation |
Immediately after creation, opens the Edit Design Layers or Edit Sheet Layers dialog box to set the properties of the new layer; see Setting design layer properties or Setting sheet layer properties |
The layers display in the Layers list on the Organization dialog box, View bar, Object Info palette and (for Vectorworks Design Suite) the Navigation palette. If the layer is created from anywhere other than the Object Info palette, it becomes the active layer.
