Creating a polygon or polyline from walls
Command |
Workspace: Path |
Create Polys from Walls |
Design Suite, Architect: AEC Landmark: Landmark > Architectural Spotlight: Spotlight > Architectural |
You can create a polygon or polyline based on either the gross area or net area of walls. This is useful for calculating the area of a room, for example, or for using color to differentiate among rooms.
To create a polygon or polyline based on the perimeter of the walls:
Select the walls to use for the polygon or polyline. Multiple walls can be selected to create several polygons or polylines at the same time.
Select the command.
The Create Polys from Walls dialog box opens.
Parameter |
Description |
Gross Area Polys |
Creates a polygon or polyline from the exterior perimeter of the selected walls |
Net Area (Room) Polys |
Creates a polygon or polyline from the interior perimeter of the selected walls |
