Adding a wall peak
Mode |
Tool |
Tool set |
Add 3D Wall Peaks
Edit Wall
Building Shell |
To add a wall peak:
In a 3D view, select the wall that requires a peak (vertex).
Click the tool and mode.
Click a corner handle or an existing vertex, and move the cursor to the location of the vertex to be added.
Click to place the vertex.
Click a corner handle, and then click again to add a peak
Use the Fit Walls to Objects command to automatically fit walls to selected geometry (Vectorworks Architect or Landmark required).
To reshape a curved wall to match a planar surface, use the Subtract Solids or Intersect Solids command with an object that matches the plane of the roof.
