T wall joins
Mode |
Tool |
Tool set |
Shortcut |
T Join
Wall Join
Building Shell |
Alt+J (Windows) Option+J (Mac) |
T Join mode lengthens or shortens the first wall segment selected until it intersects with the second wall segment selected. As only the first wall is altered, this mode does not create corner joins.
To join walls with the T Join mode:
Click the tool and mode.
Alternatively, right-click on the first wall to join and select Join from the context menu.
Select the wall segment that must change length to intersect with the other wall.
Select the second wall segment to join.
To create a T join to an existing corner, join the wall segment to the perpendicular corner segment. This creates a clean join between the walls.
Two walls are already corner joined; the third wall is joined to the perpendicular segment of the existing corner join
