Design SuiteFillet welding symbol
Mode
Tool
Workspace: Tool set
Welding Sym-Fillet
Design Suite, Architect, Spotlight: Dims/Notes
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple welding tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a fillet welding symbol:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Once the object has been placed, its marker can be selected from the Attributes palette (see Marker attributes).
Parameter
Description
Rotation
Specifies the number of degrees to rotate the object (0.00 is horizontal)
Text Style
Select a text style from a library or the current file. To use the style defined for the object's class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text.
Symmetrical (both sides the same as Arrow Side)
(AWS only)
Reflects the same information on both the arrow side and the other side
Configuration
(ISO only)
Select the data display configuration; if symmetrical is selected, the data on the other side is identical to the arrow side
Arrow Side/Other Side
Select to display data on the arrow side, other side or both; if symmetrical is selected, the displayed data applies to both sides
Weld Size
Displays the size of the weld
Number of Welds
(ISO only)
Displays the number of welds
Length of Weld
Displays the length of the weld
Pitch/Spacing
Displays the pitch or spacing of the weld
Finish Contour
Select the finish contour type
Finish Method
Select the finish method type. A finish contour must be selected in order to display a finish method.
Stagger
Indicates staggered welds
Arrow
Sets whether to have an arrow on the leader line
Position
Select the side from which the arrow on the leader line extends (left or right)
Reference
Specify whether to include a reference note
Position
Select the position of the reference note; by default, Left is selected if the arrow is on the right, or Right is selected if the arrow is on the left
Ref. Line 1
If desired, enter the data to display in the first reference line
Ref. Line 2
If desired, enter the data to display in the second reference line
Ref. Line 3
If desired, enter the data to display in the third reference line
Weld All Around
Places a weld all around the marker
Field Weld
Places a field weld flag
Position
Sets the position of the field weld flag. Select Top |> to have the flag on top facing right, Top <| to have the flag on top facing left, Bottom |> to have the flag on bottom facing right, Bottom <| to have the flag on bottom facing left.
Welding symbols
Editing the welding symbol arrow segment
Marker attributes
