Design SuiteFlange welding symbol
Mode
Tool
Workspace: Tool set
Welding Sym-Flange
Design Suite, Architect, Spotlight: Dims/Notes
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple welding tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a flange welding symbol:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Once the object has been placed, its marker can be selected from the Attributes palette (see Marker attributes).
Parameter
Description
Rotation
Specifies the number of degrees to rotate the object (0.00 is horizontal)
Text Style
Select a text style from a library or the current file. To use the style defined for the object's class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text.
Type of Weld
Sets the weld type
Configuration
(ISO only)
Select the data display configuration
Significance
Select to display data on the arrow side or the other side
Weld Size
Displays the size of the weld
Flange Size
Displays the size of the flange
Radius of Flange
Displays the radius of the flange
Root Opening
Displays the size of the root opening
Complete Joint Penetration
Displays a complete joint penetration marker
Arrow
Sets whether to have an arrow on the leader line
Position
Select the side from which the arrow on the leader line extends (left or right)
Reference
Specify whether to include a reference note
Position
Select the position of the reference note; by default, Left is selected if the arrow is on the right, or Right is selected if the arrow is on the left
Ref. Line 1
If needed, enter the data to display in the first reference line
Ref. Line 2
If needed, enter the data to display in the second reference line
Ref. Line 3
If needed, enter the data to display in the third reference line
Field Weld
Places a field weld flag
Position
Sets the position of the field weld flag. Select Top |> to have the flag on top facing right, Top <| to have the flag on top facing left, Bottom |> to have the flag on bottom facing right, Bottom <| to have the flag on bottom facing left.
Welding symbols
Editing the welding symbol arrow segment
Marker attributes
