SpotlightSetting cable preferences
Set the cable preferences prior to inserting cables in the drawing. Setting the spare cable lengths and selecting a cable set ensures that all cables are placed in a similar way that works with the needs of the venue.
Command
Workspace: Path
Cable Preferences
Design Suite: Entertainment > Spotlight Settings
Spotlight: Spotlight > Spotlight Settings
To set the cable preferences:
Select the command.
The Cable Preferences dialog box opens.
Click the Cable pane to specify the settings for cable objects.
Parameter
Description
General Settings
Cable Swag (%)
Sets the percentage of extra length used as swag (extra length to span gaps in the rigging) for non-horizontal cables
Spare Data Cable/ Multi Cable/ Feeder Cable/ Jumper Cable
Specifies the additional length added to the start and end of each type of cable so that the cable is not stressed to make a connection to the distributor
Automatically curve connector cables
(Distributor mode only)
Draws cables with a curve as a visual indicator of the mode, even though the cables directly connect two electrical devices
Automatically create cables when devices get connected
Draws cables between two devices once they've been connected. To specify the cable style or otherwise edit the cable, see Editing cables.
Automatically follow paths when a cable is drawn
Draws cables along existing cable paths or truss paths, using the most efficient route to connect devices
Gap Between Cables and Cable Path
Cables that overlap on a shared cable path can be drawn at an offset, so it's easier to select the individual cables. Specify the distance that separates each cable.
Two offset cables on a shared cable path
Skip twofers/threefers at circuit numbering and naming
Populates the circuit number and circuit name of lighting devices from the first connected distributor that is not a twofer or a threefer
Assign cable ID to twofers
Assigns the Cable Run ID to the twofers (see Cable settings)
Default Parts
Use Cable Set
Specify the set of cables to use, or select <All> to not be limited to a set. See Managing cable parts for details about assigning a cable to a set and creating new sets.
If you are changing the cable set, but you do not select <All>, confirm (upon exiting the dialog box) that the cable should be rebuilt with compatible parts from the newly selected set. If the parts in the new set are not compatible, the cable is not rebuilt.
Optimize Cable Configuration for
When determining cable configurations, defines how to assemble cable parts from the parts available in the set.
Fewest parts: If using the fewest number of cable parts is preferred, this option allows the cable run to be longer than the specified path. For example, a single 50 ft cable is selected for a 45 ft path, instead of using two 20 ft cables and one 5 ft cable to achieve the required length. This creates fewer connection points, and therefore, fewer failure points.
Best fit: If reaching the required length as closely as possible is preferred, this option selects cable parts to meet the specified cable path length as closely as possible. This option may use more parts, breaking long cable runs into multiple parts so they are easier to handle and not as heavy.
Fewest Parts Threshold
(Fewest parts only)
Defines the maximum length that a cable can extend beyond the required length but still be selected
Save as Default
Saves the current settings as the default settings for this and future documents
Click the Twofer Options pane to specify the settings for twofer objects. Select a default twofer distributor symbol for every cable connector type, and set the default position, offset, position placement, and auto numbering for the twofers inserted by the Cable tool.
Parameter
Description
Connector list
Lists the selected connectors and their default twofer parameters: selected symbol, initial position, 2D offset from the position, placement above or below the position (used only if the fixture is on a truss or hanging position), and automatic numbering. A check mark in the Insert column indicates that the twofer symbol and settings will be used by that connector.
Set a default twofer symbol for a connector by clicking in the Symbol column and selecting a symbol from the Resource Selector.
Add
Adds a connector and its twofer symbol to the list. Edit the line for the new entry; specify the connector parameters. Click in the Insert column to enable the twofer symbol and settings. The new connector and its settings are saved in the active file.
Delete
Removes the selected entry from the list
Edit Auto Numbering
Opens the Automatic Numbering Preferences dialog box, for setting the numbering options (see Automatic numbering parameters)
Save as Default
Saves the current settings in the dialog box as the default for this and future documents. If deselected, the current settings are saved only for the active file.
Defining preferences for a specific area
Tool
Tool set
Cable Area
Cable/Power Planning
It can be very useful to set different cable preferences for different areas and even layers of the drawing. In particular, different cable sets and other default parts settings may apply to different areas of a venue. Different teams (lighting, sound, power, video, and so on) have different requirements depending on discipline and location. Different parts of the venue can require varying amounts of slack in the cables. Define the settings in an area with the Cable Area tool.
Mode
Description
Convert
Converts an existing polyline, polygon, rectangle, circle, or arc to a cable area and applies the current preference settings
Oval
Creates an oval-shaped cable area
Rectangle
Creates a rectangular cable area
Vertex
Defines the cable area with a polyline; select a polyline creation option
Polyline creation options
For Vertex mode, selects the method for drawing the polyline upon which the object is based; see Creating polylines
Fillet Radius
For Arc Vertex polyline mode, enter the fillet radius
Automatic Numbering
When toggled on, enables automatic numbering as objects are placed
Sets the automatic numbering preferences
To define an area of cable preferences:
Click the tool. From the Tool bar, enable Automatic Numbering if desired, and specify the Automatic Numbering Preferences. See Numbering objects at placement.
Do one of the following:
Draw a closed shape using basic 2D tools. Click Convert mode from the Tool bar, and click on the existing shape.
Select a drawing mode from the Tool bar, and draw the cable area shape.
From the Object Info palette, click Settings.
The Cable Area Settings dialog box opens.
Define the preferences that apply to the area; see Setting cable preferences.
Enter a Location name for paperwork. To restrict the cable area to the current layer, select Only apply to objects on this layer from the Object Info palette.
Use the Reshape tool to change the shape of the cable area; double-click on the cable area to activate the Reshape tool, or right-click on the object and select Edit Path. Split the cable area with the Split tool.
Drawing cables
Power patching the electrical system
Concept: Power schematics
Spotlight and ConnectCAD terminology
