SpotlightCreating barriers with the Rope and Stanchion tool
Mode
Tool
Tool set
Modes for Creating polylines
Rope and Stanchion
Event
The Rope and Stanchion tool creates various types of barricades or roped-off areas for crowd control or for decorative purposes.
To insert a rope and stanchion barrier:
Click the tool and the creation mode.
Click to set the object’s start point.
Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the rope and stanchion object is complete, and then double-click.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette. Some information from parameters can also be placed on the drawing using the Text Options.
Reshape the rope and stanchion polyline with the Reshape tool.
Parameter
Description
Adjustable Length/ Total Length
Specifies the length from the first stanchion to the end stanchion; this can be changed from the Object Info palette or from the drawing. The parameter name depends on whether the object is straight or has several vertices.
Stanchions
Post Height/Post Diameter
Specifies the height and diameter of the post portion of each stanchion
Post Top Type
Select a style for the top of the post; the Simple style varies in appearance, depending on whether belt is selected for the Stringer Type
Post Color
Displays the texture or color selected in the 3D options
Base Type
Select a round or square base
Base Height/Base Width
Sets the height of the base, and the width for square base or diameter for a round base
Base Color
Stringers
Stringer Type
Select belt, rope, or chain for the type of stringer
Belt Length
For belt stringers, enter the distance between stanchions
Belt Color/Belt Clip Color
For belt stringers, displays the texture or color selected in the 3D options
Rope Length
For rope stringers, enter the distance between stanchions
Rope Diameter
For rope stringers, specify the diameter of the rope
Rope Color/Rope Cap Color
For rope stringers, displays the texture or color selected in the 3D options
Chain Length
For chain stringers, enter the distance between stanchions
Single Link Length
For chain stringers, specify the size of the chain links by entering the length of a single link
Chain Color
For chain stringers, displays the texture or color selected in the 3D options
Spacing and Counts
Ideal Spacing
Specifies the maximum distance between stanchions (as limited by the belt, rope, or chain length)
Actual Spacing
Displays the actual distance between the stanchions
End Stanchions
Select whether to display the stanchions at the beginning, end, both, or none
Total Stanchions
Displays the total number of stanchions for the selected object
Total Belts/Total Ropes/Total Chains
Displays the total number of belts, ropes, or chains for the selected object
3D Options
Specifies the appearance of applicable rope and stanchion elements in 3D views. The 3D Options dialog box opens.
For each available portion of the rope and stanchion, either select the color from the Color list, or select Custom Texture and then select the texture from the Texture list. The Object Info palette displays the color or texture selections in the relevant section.
Location, Position, Unit, Purpose, Cart ID, Vendor, Cost, Note
Adds information which can be placed on the drawing or used for reporting
Text Options
Opens the Text Options dialog box, to enable the display and format the text of labels
Default Text Positions
Restores text labels to their default positions
Classes
Opens the Classes dialog box, to specify class naming for the various portions of the rope and stanchion object. This allows portions of the object to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Rope and Stanchion Class> to place the rope and stanchion element in the same class as the soft goods object.
Class Prefix: Specifies an optional default root class naming standard for all rope and stanchion parts; click Assign Default Classes With Prefix to begin all rope and stanchion class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all rope and stanchion elements to the standard, using the Class Prefix if there is one.
Soft goods elements: For each portion of the rope and stanchion object, specifies the class name standard; the class names shown here are applied to the elements.
Update
Updates the object when changes have been made to the Object Info palette parameters
Vertex Parameters
Edits the vertices of the path object that the object is based upon; see Editing vertex-based objects
Equipment Subparts
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists.
The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane.
Equipment Virtual Parts
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette.
Edit Virtual Parts
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts
Assign Sources
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory
Formatting rope and stanchion labels
