Cabinet settings
These settings are available in the following locations:
Cabinet Preferences dialog box (creating an object)
Cabinet Settings dialog box (editing an object)
Object Info palette (editing an object)
Cabinet Style dialog box (creating or editing a style)
If a style is selected, only parameters set by instance can be edited (see Concept: Plug-in object styles). Parameters available only on the Object Info palette are listed at the bottom of the table.
You can create plug-in objects with a combination of parameters that are determined by the manufacturer’s catalog item, by style and/or by instance, and then optionally save them as a plug-in object style. Catalog parameters have a fixed value established by the manufacturer and cannot be edited by the user. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing (see Concept: Plug-in object styles).
Additional plug-in object settings for the class, the 2D component and cut plane display, and wall insertion options are available; see Additional plug-in object style and instance options.
Cabinet settings: Overall
Click to show/hide parameters.Click to show/hide parameters.
Parameter |
Description |
Use Style |
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing. |
By Style/Instance/Catalog |
A graphic indicates whether each parameter within the style is set to By Catalog and defined by the catalog item, set to By Style and given a fixed value by the user, or set to By Instance and editable in the dialog box. An object style may have a combination of all three of these settings, to balance the need for consistency and flexibility. By Style/Instance/Catalog settings are established by the style and cannot be changed from the settings dialog box.
To edit the object style, see Editing plug-in object styles; editing the style modifies all plug-in objects in the file that use the style. |
Select from Catalog
If the catalog item is set by instance, opens the Catalog dialog box for selecting catalog items for plug-in object styles (see Selecting catalog items for plug-in object styles). If a current catalog item is associated with the style, static text displays the item’s description. The catalog item itself can be set to By Style (to ensure that all objects using that style use the same catalog item) or to By Instance (if, for example, different sizes of the otherwise identical object require different catalog items). |
Preview |
Dynamically displays two previews of the cabinet with different sets of controls |
View |
Select the standard view for the preview of the cabinet |
Render |
Select the render mode for the preview of the cabinet |
Detail Level |
Select the detail level for the preview of the cabinet |
Object Info palette only |
Style |
Replace, edit, or remove the current style, or (for unstyled objects only) create a new plug-in style (see Custom plug-in object styles without catalog options). Editing a style changes all instances in the file that use the style. |
Hide style parameters |
Hides the parameters that are set by style; these cannot be edited from the Object Info palette |
Cabinet Settings |
Opens the Cabinet Settings dialog box |
Face Items/3D Attributes/3D Detail Levels |
Opens the appropriate pane of the Cabinet Settings dialog box |
Cabinet settings: General pane
Parameter |
Description |
General |
Cabinet Type |
Select the type of cabinet. The cabinet type and the configuration options are interdependent. Changing the Cabinet Type changes the available Box and Face options as well as Face Items options. Changing the Box setting changes the Face options and Face Items options. Changing the Face setting changes the Face Items options. These interactions also affect which of these parameters can be set by style or by instance. |
Size |
Enter the cabinet width, height, and depth |
Position (Wall cabinet only) |
Elevation |
Enter the cabinet elevation relative to the Elevation Reference |
Select the reference location for the cabinet's Elevation |
Configuration |
Options vary depending on the selected Cabinet Type |
Box |
Select a box configuration |
Frame |
Select a frame option; this option is grayed if Face is set to By Style |
Face |
Select a face configuration of doors and drawers; the Face Items list automatically updates to match the selection. Select Custom to specify a different combination of face items. |
Face Items |
The list browser reflects the selected Face setting or the custom cabinet face you design. Click a row to edit it using the parameters below. Click and drag items in the # column to change the stacking order of the face items. Click the Calculate Item/Opening Height column to toggle between having the item/opening height automatically calculated |
Add New |
Adds a face item |
Delete |
Removes the selected face item |
Move Up |
Moves the selected face item up |
Move Down |
Moves the selected face item down |
Item Type |
Select the face item type |
Define item/opening height |
If the Calculate Item/Opening Height column is set for manual entry, select whether to define the item height or opening height, and then enter the desired value. The other height is automatically calculated. |
Shelves |
Enter the number of shelves within the face item |
Drawer Configuration |
Select the Primary or Secondary configuration, as defined by the Drawer pane |
Handle Reference |
Select the reference location for the handle offset on the selected face item |
Glazed |
Creates glazed doors for the face item |
Cabinet settings: Cabinet Box pane
Parameter |
Description |
Box |
Box Thickness |
Sets the thickness of the box |
Blind Width |
For Blind Left or Blind Right Box configurations, enter the cabinet blind width |
Top Stretchers |
Front stretcher |
Adds a top stretcher to the cabinet front; select the type of stretcher |
Back stretcher |
Adds a top stretcher to the cabinet back; select the type of stretcher |
Width |
Sets the width for the top stretchers; thickness is based on cabinet box thickness |
Shelves |
Shelf Thickness |
Sets the thickness for the shelf |
Shelf Depth |
Sets the depth for the shelf |
Base (Base and tall cabinets only) |
Base Type |
Select the base type for the cabinet |
Base Height |
Enter the base height |
Base Inset |
Enter the base inset |
Apply Kick/Inset |
Select the sides to receive a kick/inset |
Leg Shape |
If the Base Type is Legs, select the leg shape |
Leg Width/Diam |
Enter the width for square legs or diameter for round legs |
Toe kick trim |
Select to show toe kick trim |
Trim Thickness |
Enter the trim thickness for the toe kick |
Extend Side to Floor |
Select the sides of the cabinet to extend to the floor, enclosing the toe kick on the sides |
Cabinet settings: Face Frame/Reveals pane
Parameter |
Description |
Face Frame |
For framed Frame configurations (General pane), enter the face frame measurements. Select the sides to apply face frame extensions, and enter a value for the frame extension length. The Appliance Rail Width option is available when a cabinet contains appliance openings in order to cover the top and bottom cabinet space of an appliance. |
Door/Drawer Reveal |
Apply reveals for inset configurations |
Allows reveals to modify face item geometry for inset configurations. Reveals apply for inset cabinets (both framed and frameless) and can be configured for use as handles. Negative bottom reveals can be used as handles for wall cabinets with overlay Frame configurations (General pane). |
Reveals |
Enter the reveal dimensions for each listed part, or click the Link button to match the reveal to the one above it |
Cabinet settings: Door pane
Parameter |
Description |
Door/Drawer |
Door/Drawer Thickness |
Enter the door/drawer thickness |
Door |
Door Type |
Select the cabinet door type; available door options will vary depending on the selected Door Type |
Vertical/Horizontal Panels |
Enter the number of vertical and/or horizontal panels |
Arch Height Factor |
Enter a multiplier of the Rail Width value to define the arch height; a larger value produces a taller arch |
Rail Width |
Enter the rail width |
Stile Width |
Enter the stile width |
Edge chamfer width |
Select to add chamfers to the outer edges of the door, and enter the width |
Inner chamfer width |
Select to add chamfers to the inner edges of the door stiles and rails, and enter the width |
Panel Type |
Select the door panel type |
Bead Width |
For a Beaded Panel Type, enter the width for the bead |
Bead Distance |
For a Beaded Panel Type, enter the distance between beads |
Door Glazing |
Muntin Type |
Select the muntin type for the door |
Vertical/Horizontal Lights |
Enter the number of vertical lights and/or horizontal lights |
Muntin Width |
Enter the muntin width |
Cabinet settings: Drawer pane
Parameter |
Description |
Primary/Secondary Drawer |
Use Settings From |
Select an item to match settings from or select <None> to set independently |
Drawer Type |
Select the drawer type; available options vary depending on the selected type |
Rail Width |
Stile Width |
Select to add chamfers to the outer edges of the drawer, and enter the width |
Select to add chamfers to the inner edges of the drawer stiles and rails, and enter the width |
Panel Type |
Select the drawer panel type |
Bead Width |
Bead Distance |
Cabinet settings: Hardware pane
Parameter |
Description |
Door/Drawer Handle |
Match door handle type |
Sets the drawer handle the same as the door handle settings |
Handle Type |
Select the type of handle; available options vary depending on the selected type. If Knob/Handle (Custom) is selected, click Choose to select a handle symbol from the Resource Selector. |
Symbol |
Displays the name of the selected handle if a symbol is used |
Extrude Depth |
Enter the depth of the extruded handle |
Channel/Extrude Height |
Enter the height of the channel or extruded handle |
Channel/Extrude Length |
Enter the length of the channel or extruded handle |
Double handles on full-width doors/drawers |
Places two handles on full-width doors/drawers |
Handles on false drawers |
Places handles on false drawers |
Set offset(s) manually |
Disables automatic handle insertion calculations; enter the offset distance |
Horizontal/Vertical Offset |
Enter the horizontal (door only) and/or vertical offset of the door/drawer handles |
Cabinet settings: Finish Options pane
Parameter |
Description |
Cabinet Finishes |
Exterior Left/Right/Back |
Select a finish option for the left side, right side, and/or back of the cabinet |
Interior |
Select a finish option for the interior of the cabinet |
Exterior Finish - Front Edges |
Select a finish option for the exterior front edges of the cabinet |
End Panel Finishes |
End Panel |
If the Box configuration on the General pane is set to an End Panel setting, select a finish option for the end panel of the cabinet |
Number of False Doors |
If End Panel is set to False Doors, enter the number of false doors |
Cabinet settings: Classes/Attributes pane
Classes, materials, and textures can be set for individual cabinet parts. The class controls the part's appearance and visibility. The visibility of the overall 3D cabinet is controlled by the Class setting from the Object Info palette. If a material resource is used to define a part, the material typically provides the fills, texture, physical attributes, and construction information needed for drawings, renderings, and reports, but the texture can be overridden.
Parameter |
Description |
3D and Visibility Classes |
Cabinet parts |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Cabinet Class> to place the part attributes in the same class as the cabinet object. |
3D Attributes |
Cabinet parts |
Lists all parts that can be assigned an individual material and texture. Select one or more rows, and do any of the following: Click in the Material column and select a material from the Resource Selector. Click in the Texture column and select a texture from the Resource Selector, or click one of the buttons to use no texture, to use the class texture, or if the material's texture was previously overridden, to revert to the material's texture. The material and texture of all selected parts are assigned. |
Cabinet settings: Visualization pane
Parameter |
Description |
2D Visualization |
Show box diagonals in Top/Plan |
Shows diagonal lines connecting cabinet box corners in Top/Plan view |
Show doors/drawers closed in Top/Plan |
Shows doors/drawers closed in Top/Plan view |
2D Cabinet Box Class |
To control visibility and appearance, select a class from the list of classes present in the drawing, or create a new class. Select <Cabinet Class> to place the 2D cabinet box in the same class as the cabinet object. |
Show door/drawer paths in Top/Plan |
Shows door/drawer operation paths in Top/Plan view |
Door/Drawer Path Class |
To control visibility and appearance, select a class from the list of classes present in the drawing, or create a new class. Select <Cabinet Class> to place the door/drawer path in the same class as the cabinet object. |
Show kick/inset in Top/Plan |
Shows the location of the kick/inset in Top/Plan view |
Kick/Inset Class |
To control visibility and appearance, select a class from the list of classes present in the drawing, or create a new class. Select <Cabinet Class> to place the kick/inset in the same class as the cabinet object. |
3D Visualization |
Draw doors open in 3D |
Draws 3D doors as open at the specified Open Angle |
Show marker on doors |
Draws lines representing the hinge direction on the front face of cabinet doors |
Hinge Direction Marker Class |
To control visibility and appearance, if Show marker on doors is selected, select a class from the list of classes present in the drawing, or create a new class. Select <Cabinet Class> to place the hinge marker in the same class as the cabinet object. |
Marker Points Towards |
Set the hinge direction marker to point toward the hinge or toward the handle |
3D Detail Levels |
Vectorworks automatically produces cabinet representations in low, medium, and high detail levels for display at different scales, but some cabinet parts are left for you to determine. Set the detail levels for the listed cabinet parts to display in a design layer view or viewport. Vectorworks can automatically display the desired detail level based on the design layer's scale; see Document preferences: Display tab. Different levels of detail can also display for different scale viewports. Once the cabinet parts' detail levels are established, set each viewport to display the desired Detail Level when creating the viewport, or set this from the Object Info palette. |
Cabinet settings: Data pane
Certain data fields cannot be edited.
Parameter |
Description |
Field Name/Field Value |
Data fields are listed under Field Name. Click the Field Value column to enter data for use in the cabinet schedule, as needed. |
or manually entered
