Bridle properties
Bridle parameters can be viewed and edited from the Object Info palette. The available leg length parameters depend on the bridle type.
Parameter |
Description |
X/Y/Z |
Specifies the location of the bridle |
Rotation |
Rotates the bridle object on its Z axis; the bridle rotates around its insertion point |
Text Style |
Select a text style from a library or the current file. To use the style defined for the object's class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text. To maintain proper size and arrow location, the measurement label may not use all the specified text style attributes. |
Style |
Replace, edit, or remove the current style, or (for unstyled objects only) create a new plug-in style (see Custom plug-in object styles without catalog options). Editing a style changes all instances in the file that use the style. |
Type |
Displays the bridle type |
Properties |
Name |
Enter a name for the bridle object, for identification and reporting purposes |
ID |
Enter a unique ID for the bridle object, for use in reports |
Location |
Specify the location of the bridle object, for use in reports |
Weight |
Enter the total weight of the bridle |
Time |
Enter the time needed for bridle assembly |
Cost |
Enter the cost of bridle assembly |
Edit Bridle Preferences |
Opens the Bridle Preferences dialog box |
Bridle Configuration |
Opens the Bridle Configuration dialog box, to assign bridle parts manually; see Adjusting the bridle configuration |
Forces |
Allowable Force Leg __ / Allowable Force Down Leg |
Enter the maximum force that the bridle leg and down leg can support; this value automatically updates if the leg parts are changed |
Force Leg __ / Force Down Leg |
Displays the force applied to the bridle leg and down leg (Braceworks required for calculated value) |
Designed Length |
Displays the bridle dimensions based on the object insertion points |
Apex Height |
Displays the height of the apex point, where all bridle legs meet. If a new value is entered, the bridle object is updated. |
Down Leg Length |
Displays the down leg length, measured from the apex point to the bottom of the leg. If a new value is entered, the bridle object is updated. |
Replace Down Leg with Hoist |
Opens the Select Hoist dialog box, to replace the down leg with a hoist symbol. Select the symbol to insert. |
Trim Leg __ |
Displays the Z height of the bottom of the bridle leg. If a new value is entered, the bridle object is updated. |
Length Leg __ |
Displays the length of the bridle leg |
Angle Leg __ |
Displays the angle of the bridle leg |
Parts Length |
Displays the parameters of the bridle based on the assigned parts |
Show Parts Length |
Draws the bridle legs with the specified parts; the parts length may differ from the original design, depending on the available parts |
Simple 3D Parts |
Draws a simple 3D representation of the bridle |
Delta from Parts Length |
Displays the offset between the Designed Length and the actual Parts Length |
Parts Length Leg __ |
Displays the length of the bridle leg as built from the specified parts |
Assign Parts automatically |
Configures the bridle automatically from the best available parts. The list of available parts can be edited; see Managing bridle parts. |
Reference Point |
Reference Point |
Select the drawing origin to use as a location reference, or use a hoist origin as the reference |
X/Y |
Displays the X and Y coordinates of the bridle object relative to the selected origin |
Display |
Use default coloring |
Uses default coloring for the bridle connection points. Otherwise, set the color from the Attributes palette; see The Attributes palette. |
Classes |
Opens the Classes dialog box, to specify class naming for the various portions of the bridle object. This allows the bridle legs, leg label, and connection marker to be set to visible, grayed, or invisible. Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Class Prefix: Specifies an optional default root class naming standard for all bridle parts; click Assign Default Classes With Prefix to begin all bridle class names with the prefix, so that they are sorted together. Assign Default Classes With Prefix: Sets the class names for all bridle elements to the standard. Bridle elements: For each portion of the bridle object, specifies the class name standard; the class names shown here are applied to the elements. |
Equipment Subparts |
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists. The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane. |
Equipment Virtual Parts |
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette. |
Edit Virtual Parts |
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts |
Assign Sources |
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory |
