Importing Cinema 4D textures
Command
Path
Import Cinema 4D Textures
File > Import
Cinema 4D four-channel color/transparency/reflectance/bump textures can be imported for use as a resource in Vectorworks files, even if you do not own a copy of Cinema 4D. The imported textures can be edited from the Edit Texture dialog box (see Editing textures and shaders from the Resource Manager).
Redshift Standard or node-based Cinema 4D textures can't be imported.
To import Cinema 4D textures:
Select the command.
The Choose Cinema 4D dialog box opens.
Select the file with the textures to import.
The Vectorworks software creates a texture resource folder with the same name as the source Cinema 4D file. The textures are placed in the folder, which is accessible from the Resource Manager.
