Aligning and distributing objects in 3D
Command
Path
Shortcut
Align/Distribute 3D
Modify > Align
Ctrl+Shift+= (Windows)
Cmd+Shift+= (Mac)
Objects can be aligned and/or distributed in relation to each other in 3D space. 3D object alignment/distribution is based on either the ground or working plane.
The Align/Distribute 3D command aligns and distributes multiple objects. Alignment and distribution are based upon the X, Y, and Z axes of the active layer plane or the X’, Y’, and Z’ axes of the working plane.
Keep in mind the following points about this command:
3D loci and locked objects are special objects and behave differently when present during an alignment/distribution operation.
If a 3D locus point is one of the selected objects, all objects are aligned relative to that locus. If there are multiple loci in the selection, then the loci are aligned/distributed like any other object.
Locked objects in a selection do not move. Other objects are aligned/distributed relative to the locked objects.
2D objects are ignored by the Align/Distribute 3D command.
To align/distribute objects in 3D:
Select the objects to be aligned/distributed.
Select the command.
The 3D Object Align and Distribute dialog box opens. Select the alignment/distribution criteria.
Parameter
Description
Alignment/Distribution Axes
Select whether to align/distribute using the axes of the active layer plane or the working plane
Align/Distribute
Select Align and specify the coordinate value to use when aligning objects, or select Distribute to distribute objects
Minimum
Align/distribute objects along the specified axis by the minimum coordinate value of each object
Center
Align/distribute objects along the specified axis by the center coordinate value of each object
Insertion Point
Align/distribute by the insertion points of the selected plug-in objects and/or symbols.
If the selection contains objects without insertion points, they are aligned by their geometric centers.
Maximum
Align/distribute objects along the specified axis by the maximum coordinate value of each object
Spacing
Distribute spacing between objects along the specified axis, ensuring that the space between the objects is equal along the axis
The program aligns/distributes the selected objects.
Aligning objects to grid
