The Object Info palette
Command |
Path |
Shortcut |
Object Info |
Window > Palettes |
Ctrl+I (uppercase i, Windows) Cmd+I (uppercase i, Mac) |
The Object Info palette provides information about the selected objects in a Vectorworks drawing, and allows you to change the parameters. The information displayed depends on the type of objects selected. The Name field allows you to enter an optional identifier for the selected object.
The Object Info palette organizes data into three tabbed panes:
Tab |
Description |
Shape |
Lists parameters related to the geometry, class, layer, and location of the selected object |
Data |
Lists data attached to the selected object, including record data and IFC data |
Render |
Assigns and maps textures to 3D objects. Also controls mesh smoothing in Shaded rendering mode and Renderworks and sketch rendering styles. |
To select drop-down list items from the Object Info palette, either use the mouse or type the first letter of the desired item to highlight the closest match in the list (excluding class and layer lists).
The Utility menu on the palette's title bar allows you to customize display of the palette:
Display or hide tabs; see Displaying and hiding palettes and tabs
Dock detached tabs and lock tabs; see Detaching and returning palette tabs
Set the style of tab titles to be icons only, text only, or both icons and text
Display or hide IFC data (available on the Data tab only, Vectorworks Design Suite product required); see Assigning IFC data to objects
Display or hide world coordinates and abbreviate screen coordinate labels in rotated plan views (available on the Shape tab only, Design Suite product required); see Rotating the plan
Expand or collapse widget groups; see Widget groups
Editing multiple objects
You can select multiple objects and edit them collectively or individually from the Object Info palette. When multiple objects are selected, editing controls display at the top of each tab of the palette. Toggle the three dots between Multiple Edit mode
and Individual Edit mode
as needed.
Use Multiple Edit mode to make the same change to multiple objects of the same type. If the parameter settings of the objects are different, the field displays as blank; a check box displays with an "indeterminate state." Parameter edits affect all the selected objects in multiple edit mode.
Multiple Edit mode for objects with some different settings
To edit each object in a selection separately, click the edit control at the top of the tab to select Individual Edit mode. Use the Next and Previous arrow buttons to move forward and backward through the selected objects. Each object highlights briefly as it is selected. To be sure which object is currently selected, click the center circular button to highlight it again. If either arrow is grayed, you have reached the end of the selected objects in that direction.
Individual Edit mode within a multiple selection
Saving the Object Info palette settings
Command |
Path |
Save Palette Positions |
Window > Palettes |
Set the Object Info palette position, active pane upon opening, and Data tab separator position, as described in Saving palette positions and settings.
To save palette positions and settings, select the command.
To revert the palette position and settings back to the settings established when the custom workspace was created (in the User Data and Preferences folder), click Reset Saved Settings from the Session pane of Vectorworks preferences (see Vectorworks preferences: Session pane).
Activating the Object Info palette
Command |
Path |
Shortcut |
Activate Object Info Palette |
Window > Palettes |
Ctrl+‘ (back quote, Windows) Cmd+Option+C (Mac) |
To activate the Object Info palette with an object selected in the drawing area, select the command.
The keyboard shortcut allows you to quickly switch the focus from the drawing area to the first editable field on the active tab of the Object Info palette. If the Object Info palette is not open, or is minimized (unpinned), the Object Info palette is opened, and then the first editable field is highlighted. The shortcut key can be set in the workspace editor.
Other object editing options
An object's properties dialog box contains information very similar to the Object Info palette. Right-click the object and select Properties from the context menu to access the properties dialog box.
For some objects, such as doors and symbols, the Edit command on the context menu opens a dialog box to access additional editing functions.
Double-clicking an object performs the same function as selecting Edit from the context menu (it also reactivates the working plane on which a planar object was created).
