LandmarkCreating parking along a path
Tool
Tool set
Parking Along Path
Site Planning
To create parking along a path:
Click the tool.
Click to begin drawing the parking polyline path; click to set each polyline vertex. Click again back at the start point (or press K) to complete a closed polyline, or double-click to create an open polyline. For more information on polylines, see Creating polylines.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited from the Object Info palette.
The parking spaces are automatically created along the polyline path.
Parking Along Path tool in Bézier Vertex mode
Once created, the parking along path object can be edited by selecting the parking object; then select Modify > Edit Parking Along Path and reshape the parking area polyline with the Reshape tool; click Exit Path to return to the drawing.
Parking along path parameters can be edited from the Object Info palette.
Parameter
Description
Rotation
Specifies the number of degrees to rotate the object (0.00 is horizontal)
Text Style
Select a text style from a library or the current file. To use the style defined for the object’s class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text.
Space Width
Indicates the width of each parking space. Spaces along a curve may widen along the length of the space; the space width is defined as the minimum width between the two sides.
Space Length
Indicates the length of each parking space
Space Numbering
Adds a parking space number to each parking space; spaces are numbered from left to right and top to bottom
Start Num At
Specifies the starting number to begin parking space numbering
Num Spaces
Displays the number of parking spaces created
Spaces on Left of Poly
Includes spaces along the left side of the parking path
Spaces on Right of Poly
Includes spaces along the right side of the parking path
Aerial parking lot photo with curved parking along path superimposed
Parking tools
